Date/Time: Tue, 22 Apr 2025 23:22:03 +0000
Can’t reopen all services window after minimizing
View Count: 384
[2023-03-22 13:39:51] |
User160486 - Posts: 40 |
My main chart window will not maximize again after minimization. I minimize it to open up another program and I can’t maximize it after. My charts on my second screen stay open and the program is on and running but I just can’t reopen the main chart window. I put my mouse over the sierra chart chart book window on the bottom but it will not let me maximize the window.
[2023-03-22 14:13:02] |
Sierra_Chart Engineering - Posts: 19305 |
Try terminating the SierraChart_64.exe process through the operating system Task Manager and start Sierra Chart again and see if the main window becomes visible. If that does not help we have another idea. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-03-22 14:13:21
[2023-03-28 09:07:54] |
Hello. Unfortunately that did not work. It stopped doing it for a few days but now I am having the same problem not only with the main chart window on my left screen but with my right screen too - when I minimize each individual chart on my right screen I am unable to reopen them. Please help!
[2023-03-28 22:41:54] |
Try going to an earlier global configuration file: Resetting Sierra Chart to a Default State / Restoring Backup Global Configuration File: Restoring Backup Global Configuration File Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
