Date/Time: Tue, 22 Apr 2025 23:19:20 +0000
EUREX-FBGS (German 2Yr
View Count: 418
[2023-03-22 08:19:07] |
User551647 - Posts: 25 |
Dear Sierra Charts Team, could you add the EUREX symbol FGBS (German 2Yr "Schatz") to the Trading Evaluator? With it the German curve would be complete. Thank you very much. |
[2023-03-23 13:36:03] |
Sierra_Chart Engineering - Posts: 19305 |
Yes we will do that.
[2023-03-23 15:11:38] |
Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings The new symbol should go into effect this evening. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-03-23 15:11:45
[2023-03-23 18:12:44] |
It works. Thanks you very much! |
[2023-03-23 19:48:38] |
User90125 - Posts: 715 |
Would it also be possible to add EUREX symbol FGBX (German 30Yr "Euro-Buxl" bonds) to the Trading Evaluator, if it's not already available? Thanks. |
[2023-03-25 08:01:43] |
It is already listed.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-03-25 08:01:48
