Date/Time: Mon, 16 Sep 2024 19:07:02 +0000
turning on/off the position line in a chart
View Count: 1421
[2014-06-18 01:44:03] |
User32803 - Posts: 18 |
How do you turn on and off the position line in a chart. Also can the color be changed.
[2014-06-18 10:27:37] |
This is controlled through Trade >> Show Orders and Position or Trade >> Chart Trade Mode On. Complete documentation can be found here: http://www.sierrachart.com/index.php?l=doc/doc_ChartTrading.html#ViewingOrdersOnTheChart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-06-18 10:28:50
[2014-06-18 16:54:57] |
eagle - Posts: 92 |
This is controlled through Trade >> Show Orders and Position or Trade >> Chart Trade Mode On. In recent versions position is showing on charts with neither of those two options selected.1. Is there a new option somewhere that has an effect on the showing of position on charts? 2. Is there a programming error in recent versions regarding the showing of position on charts? Date Time Of Last Edit: 2014-06-18 16:55:40
[2014-06-18 17:00:21] |
snillumat - Posts: 29 |
same problem here. I had to downgrade back to ver 1140.
[2014-06-18 17:13:52] |
We need to correct this.
[2014-06-19 23:42:08] |
Does engineering have any time frame as to when this problem will be resolved? On small charts the position line interferes with the bar data. If the position line is blacked out, the bar data is also blacked out.
[2014-06-19 23:46:26] |
This has been already all been released. The version number has not changed. Update Sierra Chart with Help >> Download Prerelease.
