Date/Time: Tue, 22 Apr 2025 18:28:08 +0000
Minimum tick sizes in SC
View Count: 432
[2023-03-21 18:08:49] |
onnb - Posts: 663 |
In the chart settings, I am trying to set a tick size of 1e-8 I can enter tick size as small as 1e-6 When I try and set 1e-7 or smaller, SC reverts the setting back to 0.01 Is that expected? In general, is there a limitation on the tick size and is there a way to allow smaller ones? |
[2023-03-21 22:09:30] |
John - SC Support - Posts: 39418 |
You have found the limit. That is as small as it can go.
