Date/Time: Tue, 22 Apr 2025 18:16:45 +0000
DOM Current Bid/Ask Histogram Scaling Issue
View Count: 443
[2023-03-21 18:06:42]
TopGunTrader - Posts: 191
I just noticed with a hug 744 buy contracts two times more than left side's bid below is the same size. Is there a scaling method to scale to LARGEST of both sides?
Pic shows the problem the 744 is almost double the 351 and 399 ON left but looks identical.
imageCapture.PNG / V - Attached On 2023-03-21 18:06:33 UTC - Size: 29.02 KB - 103 views
[2023-03-21 22:07:27]
John - SC Support - Posts: 39416
Refer to the following:
Global Trade Settings Windows: Recent/Current Volume Bars Length Relative to Bid and Ask (Global Settings >> Chart DOM Settings >> Other >> Other Settings)
