Date/Time: Tue, 22 Apr 2025 18:30:44 +0000
SC 2084 issues with TMS and position display from SC2080
View Count: 370
[2023-03-21 14:54:46] |
User185210 - Posts: 66 |
Hello, Just updated to SC2084 from SC2080 and having problems with TMS not working and average Position not diplayed! My setup is IB + SC + Denali, with chart setting Trading for open Position using: "use external Service Open Position Average Price" Is this something known or should I modify something else? Any help is welcome! Thank you, Paul |
[2023-03-21 15:05:39] |
Sierra_Chart Engineering - Posts: 19305 |
In the case of Interactive Brokers, Sierra Chart no longer supports the Position Average Price from TWS. So it is probably related to that. So you cannot use the external service average price. You have to use one of the other average price options. What problem are you having with the Trade Management study? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-03-21 15:20:50
[2023-03-21 15:15:50] |
Tms not active! as if its disconected!
[2023-03-21 15:51:53] |
After changing the position average price to "flat to flat open position...", tms active as should be! So it works fine again! Thank you |
[2023-03-21 17:18:08] |
Ok this is very good.
