Date/Time: Tue, 22 Apr 2025 18:28:08 +0000
Background coloring only showing range 0 colors for number bars
View Count: 277
[2023-03-21 14:23:23] |
User454729 - Posts: 22 |
Hi there, My settings for number bars column 2 are as follows: number bar text ln28: bid vol x ask vol background type ln29: ask/bid vol split profile background coloring method ln 29: based on askvol/bidvol percentage text coloring method ln 31: none column 2 percent compare thresholds ln92 .25,.50,.75 (default setting) I have different colors set up for range 0 to 3 on both up and down However the number bars coloring is only displaying the range 0 colors. Please help. thank you |
[2023-03-21 14:26:14] |
Sierra_Chart Engineering - Posts: 19305 |
Attach that chart by following these instructions: Support Board Posting Information: Providing Chartbook with Only a Single Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
