Date/Time: Tue, 26 Nov 2024 20:19:27 +0000
What indicator to make single horizontal colored bar?
View Count: 1007
[2014-06-17 20:41:13] |
Willson - Posts: 176 |
I need to create a single horizontal bar that contains the color changes occurring in another study. For example I have a MA of price. It changes color and amplitude. I want to view color only and have adjustable thickness of this indicator. Any suggestions? I think such a study exists, just can't find it. Regards |
[2014-06-18 09:54:01] |
You can use the Color Bar based on Alert Condition study. It can be used to draw study lines as well, based on specified conditions. Refer to the documentation for it here: http://www.sierrachart.com/index.php?l=doc/doc_TechnicalStudiesReference.html#s245 This is a very versatile study. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
