Date/Time: Tue, 22 Apr 2025 18:28:09 +0000
Synchronize Drawings Across Regions on the Same Chart
View Count: 337
[2023-03-21 05:57:15]
User688525 - Posts: 284
Hello Sierra Chart,
Is it possible to synchronise drawings across regions on the same chart? For example, if a chart has two regions (Chart Region 1 and Chart Region 2), if drawing a trendline on Chart Region 2, can this be made to automatically appear on Chart Region 1 above, and vice-versa. This would be very beneficial if drawing divergent trendlines, etc.
Thank you
[2023-03-21 14:30:26]
Sierra_Chart Engineering - Posts: 19305
No, this is not supported. You would have to develop this functionality yourself using ACSIL:
Using Drawing Tools From an Advanced Custom Study
Date Time Of Last Edit: 2023-03-21 14:30:51
[2023-03-21 17:03:53]
Hello Sierra Chart,
Thank you for confirming.
