Date/Time: Tue, 26 Nov 2024 20:03:30 +0000
Upgraded to Sierra real time data, then lost Market Depth from OEC
View Count: 1002
[2014-06-17 20:23:06] |
User48838 - Posts: 120 |
I upgraded this morning to Real Time Sierra data. Prior I had been using OEC and the market data was coming thru to the DOM. After reloading Sierra i could not get the market depth. Any ideas what happened? |
[2014-06-17 22:07:33] |
If you want market depth you need to choose the 15.75 CME exchange fee here: https://www.sierrachart.com/usercp.php?page=SC_RealTime_DataFeed_SetExchanges Sierra Chart does not support accessing market data from two different sources for the same symbol in the same copy of Sierra Chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
