Date/Time: Tue, 22 Apr 2025 18:22:19 +0000
DOM for every charts shows only two 1's.
View Count: 355
[2023-03-20 21:45:23]
User203105 - Posts: 2
I can't get DOM working properly. They seem to be empty for both Trading DOM window and DOM showed in the chart. I'm only getting two 1's:
imageSC_DOM.png / V - Attached On 2023-03-20 21:44:24 UTC - Size: 60.31 KB - 91 views
[2023-03-20 22:04:49]
John - SC Support - Posts: 39418
We do not have Market Depth data for the CFDs. The symbol you are using (SPX500) is a CFD symbol.
[2023-03-21 08:41:41]
Could you give me tickers for DAX/NASDAQ/SP500 instruments that do have the market depth avaliable?
[2023-03-21 08:46:40]
Sierra_Chart Engineering - Posts: 19305
You need to use EUREX and CME Group futures for these. You will find these symbols in File >> Find Symbol-EUREX/CME.
Date Time Of Last Edit: 2023-03-21 08:46:53
