Date/Time: Tue, 22 Apr 2025 18:24:56 +0000
Accident
View Count: 333
[2023-03-20 20:39:58]
User857546 - Posts: 2
Please tell me how to deactivate "11 - Integrated Advanced (Monthly) - 46 USD / Month"
I accidentally added it again but i don't want it.
Please refund the money, I wanna buy data feed service "CME, For professionals and users without a trading account" instead.
[2023-03-20 21:57:40]
John - SC Support - Posts: 39418
You can change your package at any time. Refer to the following instructions:
To change your Sierra Chart Service Package, select "Help >> Account Control Panel" on the Sierra Chart program menu. On the displayed webpage, click on the "Set Service Package for Renewal" link.
Or go to this page:
https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation
You will need to login if you are not currently logged in.
In the "Available Services >> Choose Usage Time Service Package" frame, select the Service Package that you want to set your account to. Press the "Set" button.
The remaining service usage time on your account will be adjusted based upon the cost of the package you are changing to. If the new package is a higher-priced package, then the usage time will be reduced due to the higher price.
There is no charge for changing your Sierra Chart service package. Only your Sierra Chart account usage time ending date is adjusted.
When changing between Sierra Chart Service Packages, the usage time ending date on your Sierra Chart account is adjusted based upon the price differences between the package you are changing from and the package you are changing to.
When changing to a higher priced package, your usage time ending date will be brought back closer in time. When changing to a lower-priced package, your usage time ending date will be brought forward further out in time.
