Date/Time: Tue, 22 Apr 2025 18:19:28 +0000
Dashed lines
View Count: 409
[2023-03-20 16:13:52] |
Dylan Brooks - Posts: 3 |
There are two dashed lines showing up in my chart. I have deleted and re-downloaded data, but they won't go away. Please advise |
![]() Attachment Deleted. |
[2023-03-20 20:34:37] |
John - SC Support - Posts: 39418 |
Most likely it is from the Volume Weighted Average Price study. It is definitely from a study, and that study has the Draw Style set to Dash. In that mode, you just get a line at the level of that indicator for the bar, so it looks like what you have. You will need to figure out which study is set this way and either change the display to something you want (like a line) or remove it. Refer to the following regarding Draw Styles: Chart Studies: Subgraphs Tab >> Draw Style For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
