Date/Time: Tue, 26 Nov 2024 20:03:30 +0000
Automatically Save Trade Activity Log
View Count: 1106
[2014-06-17 19:04:58] |
User45989 - Posts: 54 |
Is there a way to automatically save the Trade Activity Log to a specified location? This would be helpful when running backtests. thank you |
[2014-06-17 19:14:57] |
You can save the contents of it as a text file through the File menu One thing we do plan to add is multiple simulation accounts that can be used for back testing. So you can run several back tests and use a different account for each. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-06-17 19:15:07
