Date/Time: Thu, 28 Nov 2024 16:35:24 +0000
[Programming Help] - cant see low of ESH3 od Dec 22 2022
View Count: 554
[2023-03-20 13:16:30]
User449884 - Posts: 155
The low of 3788 of the esh23 contract doesnt appear in any of my charts. Ive tried every load options on the menu and all i get is 3822 for that contract
[2023-03-20 14:17:47]
User90125 - Posts: 715
Load a daily Historical Chart of ESH23 and post what you see on that date.
[2023-03-20 14:46:20]
i get 3822 for dec 22 for the low
[2023-03-20 15:20:36]
My daily historical chart of ESH23 shows a low of 3788.50 on Dec 22nd 2022, which seems to be what you were expecting to see.
[2023-03-20 15:49:03]
yeah but not working on mine
[2023-03-20 16:13:34]
Only thing I can think of is that you are using an adjusted continuous contract chart. Maybe if you posted a picture of your chart, it would be helpful.
[2023-03-20 16:17:02]
yeah i checked and my settings for continuation is set to *none*.
Hoping someone from Sierra will stop by because its a big issue
[2023-03-20 16:35:13]
Just loaded a 1 min chart of ESH23 and I see a low of 3788.50 @ 13:33:00 ET on 12/22/22.
No idea why your chart is different, but good luck in sorting it out.
Date Time Of Last Edit: 2023-03-21 00:37:19
[2023-03-20 16:40:54]
yeah pulled up all types of charts and i have 3822 on that date on all of them, How can i trust any other numbers now?
[2023-03-20 20:53:43]
John - SC Support - Posts: 36350
First - if you are wanting to see the data for the H contract of 2023 for the ES, then you will need to load that specific contract by typing it in on the Find Symbol window and then opening an Intraday chart (or changing the symbol of a chart if that is how you like to do it). The point is, that the current contract is M, so you have to load the H contract separately and be sure not to roll it over (or that you have the option for "Automatically Rollover Futures Symbol" set to 'Yes' - this needs to be 'No'). Refer to the following:
Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Using Expired Futures Contracts
Note that it looks like you are using CQG for your data, so you will only be able to see the data for this symbol for which you already have data downloaded - CQG does not have previous contract data available. Your other option would be to change your service to SC Data - All Services to get the data from us.
Once you have the symbol loaded, then you need to figure out if you are wanting to view Daily Historical data, or Intraday data. The Close of each day, in particular will be different between the Intraday and Historical data. Refer to the following:
Differences With Data and Chart Bars Between Services / Connections / Chart Types: 43.6 - Differences Between Close Prices on Historical Daily Charts Compared to Intraday Charts
After you work out the above, then you can view the particular item you are trying to find.
[2023-04-13 20:08:43]
i can see the low of Dec 22 2023 properly, if i switch to ESH23, but as soon as i roll it or change to the current contract, its a different low
[2023-04-13 20:46:33]
What is Chart >> Chart Settings >> Symbol >> Continuous Contract set to?
[2023-04-14 15:55:57]
Volume based, back date adjusted
[2023-04-14 16:25:08]
Since you are using a "Back Adjusted" continuous contract, the data from the previous contracts is adjusted so that it will line up with the next forward contract (and so on, going back to the beginning of your chart). Therefore, the data displayed is no longer the exact data from that time. If this is not what you want, then do not use a Back Adjusted option. Refer to the following:
Continuous Futures Contract Charts: Controlling Rollover Amount for Back Adjustments
[2023-04-15 17:12:47]
ok that worked thanks
