Date/Time: Tue, 22 Apr 2025 18:22:19 +0000
chart drawings
View Count: 294
[2023-03-20 12:58:02] |
User491428 - Posts: 87 |
Hallo, i need to show the chart drawings in my dom window. but the lines are vertical and not horizontal like in the chart. ???
[2023-03-20 17:27:53] |
John - SC Support - Posts: 39418 |
You can not display drawings in the Trading DOM window. If you need drawings, then you would have to use the Chart with the Chart DOM on.
