Date/Time: Tue, 26 Nov 2024 20:20:40 +0000
Charts not matching up on date when looking at past data
View Count: 1052
[2014-06-17 16:42:19]
GCAdmin - Posts: 35
For some reason, when I am looking back at past data at a 60 minute chart and a one day chart, the candles are one day off. I am looking at AUDUSD symbol on SC Forex Data feed. The day chart is the only chart showing a different date. The other charts that are in the chartbook all show the data on the correct date. The day chart is showing movement that is one day old on the 60 minute chart. There is not an issue on a live feed, just on when I use the Go To feature.
This is interesting though:
I just learned about chart linking. If I...:
- link scroll position on my 60 and 1 day charts
- scroll to the most current candle
- on the day chart, scroll back to 03/19/2014
...then the candles match up.
But whether linked or unlinked, if I manually use the Go To Date function and tell the 60 and 1 day chart to go to 03/19/2014, then the day chart is always a day ahead.
Duplicating my 60 and changing it to a 1 day chart and using the GTD function yields the same problem. Any recommendations. Attached charts as well as settings.
Private File
Private File
Private File
[2014-06-18 22:16:22]
To attach an image of the chart, only use this method here:
https://www.sierrachart.com/index.php?l=PostingInformation.php#Image
We cannot understand your chart image and we generally do not understand what you are saying here.
One thing we need to make clear though is that when you create a 1 day per bar chart using an Intraday chart, the Date-Time of the bar will be the starting date-time of that bar. This could be different than a Historical Daily chart. There will only be a difference if the Session Start Time of the chart is later than the Session End Time.
With a 1 day per bar chart created from Historical Daily data, the date of each bar will have the primary trading session date.
Date Time Of Last Edit: 2014-06-18 22:18:48
