Date/Time: Tue, 22 Apr 2025 18:19:28 +0000
Current Trades Total Volume DOM
View Count: 553
[2023-03-19 23:06:18] |
Martin Wunder - Posts: 16 |
Hi,is there a way of not having the current trades total volume column delete when clearing recent bid ask volume on the DOM chart? NV with G7fx was able to do this,I have one of his DOM charts that does not clear the column,but it is not obvious how it was accomplished. Thanks Martin |
[2023-03-20 17:06:40] |
John - SC Support - Posts: 39418 |
If you are selecting the option for Trade >> Clear Recent Bid/Ask Volume, then any Current Traded columns you have displayed should not be clearing. The opposite is also true - selecting Trade >> Clear Current Traded Bid/Ask Volume will only clear the Current Traded columns. Make sure the columns you have displayed are what you think they are. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
