Date/Time: Tue, 22 Apr 2025 18:24:56 +0000
SetGraphicsSetting() API does not appear to work in v2486
View Count: 415
[2023-03-19 21:59:25]
User719512 - Posts: 309
Hi Sierra Engineering,
Noticed 3 new API in v2486.
I have successfully used the GetGraphicsSetting() API and it is returning expected results.
I then call SetGraphicsSetting() to a different chart and do not see the updated settings reflected in the chart. The API is returning 1 for all calls. Calling SetUseGlobalGraphicsSettings() before or after SetGraphicsSetting() seems to have no impact either.
Can you explain what might be happening here, and confirm these 3 new APIs are working correctly? Well, technically, just the 2 SetGraphicsSetting(), SetUseGlobalGraphicsSettings().
[2023-03-20 05:01:29]
Sierra_Chart Engineering - Posts: 19305
The implementation of these functions is not complete and they are not documented.
[2023-03-20 05:59:43]
Looking forward to when these are complete. These are great APIs.
