Date/Time: Thu, 17 Apr 2025 09:15:32 +0000
Strange behavior with Numbers Bar chart
View Count: 314
[2023-03-19 21:15:15] |
Gustavo - Posts: 74 |
Please reference the screenshot link below of the ES mini on March 17. I have noticed a strange behavior with Numbers Bar charts where the data seems incorrect. Note the bar at around time mark 10:07 / 10:08. There are several price levels with the same volume data. I don't have anything else to compare but it does not look right. This behavior repeats, the screenshot is just one example. Data is from Denali. Please let me know what you think. Thanks. Screenshot: https://www.sierrachart.com/image.php?Image=1679147908346.png |
[2023-03-19 21:15:23] |
Sierra_Chart Engineering - Posts: 19249 |
Set Sierra Chart to a Tick by Tick Data Configuration. Follow the instructions here to do this: Tick by Tick Data Configuration Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
