Date/Time: Tue, 22 Apr 2025 18:24:55 +0000
Converting Older Cht files?
View Count: 331
[2023-03-18 20:01:08] |
kienly03 - Posts: 13 |
Hi, I got a msg saying this cht file is not compatible. perhaps it's an older file designed for previous versions? I've attached it for your reference, pls let me know |
![]() Attachment Deleted. ![]() |
[2023-03-20 16:40:25] |
John - SC Support - Posts: 39418 |
Refer to the instructions to update the chartbook here: Chartbooks (Workspaces): Opening Older Chartbooks For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
