Date/Time: Tue, 22 Apr 2025 18:19:28 +0000
Convert Cht File For Compatibility
View Count: 434
[2023-03-18 14:45:16]
WesG2009 - Posts: 3
Hey,
I need these files converted so they can work with the recent version of sierra chart
attachmentG7FXPROFOOTPRINTCHARTBOOK-200409-002540.Cht - Attached On 2023-03-18 14:43:25 UTC - Size: 528.28 KB - 386 views
attachmentG7FXSTAGE1PROFILECHARTBOOK-200608-010449.Cht - Attached On 2023-03-18 14:43:38 UTC - Size: 23.05 KB - 305 views
attachmentG7FXSTAGE2FINALCHARTBOOKALL-200608-010527.Cht - Attached On 2023-03-18 14:43:46 UTC - Size: 38.03 KB - 252 views
[2023-03-18 14:46:41]
WesG2009 - Posts: 3
Also need these converted as well
attachmentG7FXSTAGE2FINALCHARTBOOKCLONLY-200608-010527.Cht - Attached On 2023-03-18 14:45:48 UTC - Size: 16.59 KB - 226 views
attachmentG7FXSTAGE2FINALCHARTBOOKESONLY-200608-010527.Cht - Attached On 2023-03-18 14:45:55 UTC - Size: 22.15 KB - 338 views
attachmentG7FXSTAGE2WKLYVWAPPROFILECHARTBOOK-200608-011835.Cht - Attached On 2023-03-18 14:46:00 UTC - Size: 28.27 KB - 286 views
[2023-03-20 15:27:42]
John - SC Support - Posts: 39418
We have been asked by G7FX to not convert their files. If you need more current versions of these, then you need to get them from G7FX.
