Date/Time: Tue, 22 Apr 2025 18:33:50 +0000
Looking to remove the circled black bars -- see the attachment
View Count: 322
[2023-03-17 19:21:28]
User967628 - Posts: 5
See the circled black bars, please tell me if I can change the color of them to match the Trader Window?
imageSierra Charts Blacked out .png / V - Attached On 2023-03-17 19:21:05 UTC - Size: 151.56 KB - 101 views
[2023-03-17 21:20:44]
John - SC Support - Posts: 39418
You can not get rid of it and you can not change it. That is the location where you are informed if the Attached Orders match the quantity of the primary order or not. You are getting the black bar because you are not using any Attached Orders.
