Date/Time: Tue, 18 Feb 2025 21:56:18 +0000
Number Format Spreadsheet
View Count: 1114
[2014-06-17 12:57:46] |
CarlRostron - Posts: 80 |
Had a look through he Documentation but cannot find my answer. Looking to format a number (FX Quote) on a spread sheet to 4 decimal places. What do I do to do this please? Thanks |
[2014-06-17 17:24:26] |
This is done through Spreadsheet >> Number Format which is documented here: http://www.sierrachart.com/index.php?l=doc/doc_WorksheetMenu.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
