Date/Time: Mon, 15 Dec 2025 09:28:33 +0000
no data
View Count: 394
| [2023-03-17 10:48:23] |
| Morgane Panglosse - Posts: 1 |
Bonjour, J'ai payé mon abonnement mais je n'ai pas de data, tout est bloqué |
| [2023-03-17 10:48:32] |
| Sierra_Chart Engineering - Posts: 21843 |
Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Open a chart for the symbol you have an issue with. Tell us that symbol of the chart. Tell us about *one* symbol only. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) We will then determine what the problem is. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
