Date/Time: Tue, 22 Apr 2025 18:33:46 +0000
Connection Status Bar
View Count: 342
[2023-03-17 08:34:27] |
Statman43 - Posts: 15 |
I am getting a GREY color for my Connection to CGQ WebAPI. I am not sure if I lost my connection because the very top line reads as follows: Sierra Chart 2484 FootPrint_PIT CQG WebAPI 2023-03-17 01:45:03 Fri [Sim] DF:25514 ST:1, 1 - (F.US.MESM23[M] 1 Min #3 [MICRO E-MINI S&P 500 FUTURES MES]. Is it possible, I somehow changed the color from bright GREEN to GRAY on my Connection Bar. By the way, it says on the bar DF:27655 ST:1, BR:742.4K |
[2023-03-17 08:34:50] |
Sierra_Chart Engineering - Posts: 19305 |
The colors are controlled through Global Settings >> Graphics Settings.
[2023-03-17 14:58:13] |
There seems to be about 40 or so lines in Global Setting >> Graphic Settings. Is it possible for you to tell me which setting controls the color of the Connection Status?
[2023-03-17 15:37:57] |
John - SC Support - Posts: 39418 |
There are 5 options that affect the status window. They start with the words Control Bar Status. The first in the list is Control Bar Status Not Connected.
