Date/Time: Sat, 04 May 2024 06:36:54 +0000
suggestion about sc.AddAndManageSingleTextUserDrawnDrawingForStudy()
View Count: 205
[2023-03-17 06:31:49] |
Tony - Posts: 460 |
Hi, Is it possible to add an option, so we can use Index and Chart Value, as well as X,Y relative positions? Thanks! |
[2023-03-17 08:29:56] |
Sierra_Chart Engineering - Posts: 14207 |
Modify the code to meet your requirements. The source code is contained within the SierraChart.h file. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-04-11 01:42:57] |
@sstfrederik - Posts: 403 |
For what its worth. Just checked the source of this study, and I guess the below code as added very recently as this functionality stopped working as expected for some of my studies. Adding this CreateNeeded does not make a lot of sense as it prevents a redraw when new values are used for the positioning when a drawing was already there. It should always create. bool CreateNeeded = r_DrawingTextLineNumber == 0; if (CreateNeeded) { Tool.BeginDateTime = HorizontalPosition; Tool.BeginValue = static_cast<float>(VerticalPosition); } Date Time Of Last Edit: 2024-04-11 01:43:29
