Date/Time: Tue, 22 Apr 2025 18:14:13 +0000
[Programming Help] - does not recognize function
View Count: 292
[2023-03-17 04:10:40]
WeroTrader - Posts: 46
Greetings
I am trying to implement a function in code that will help me fill the space between two indicators within the same code.
I tried to use "FillGraphBetweenSubgraphs" but the remote compiler gives me an error
Could you help me with any option to correct the error?
The flagged error is " error: 'struct s_sc' has no member named 'FillGraphBetweenSubgraphs' "
Thank you
[2023-03-18 03:07:55]
Tony - Posts: 565
It is probably a good idea that you post the whole source code
