Date/Time: Tue, 22 Apr 2025 18:14:11 +0000
Extended Rectangle Tool and Copy Config Name setting
View Count: 316
[2023-03-17 02:55:21] |
User423634 - Posts: 24 |
I have different config names on each preset. For example preset 1 is called "Orders" and preset 2 is call "240 Dem" why is it when I open the extended rectangle tool and change to different presents they are always labeled as the 1st preset, in this case "orders" instead of "240 Dem"
[2023-03-17 14:31:22] |
John - SC Support - Posts: 39416 |
The Copy Config Label to Text only applies when you are first creating the drawing. After it is drawn, that text is just text and the system will not update it based on changes to the Config. Therefore, you want to ensure you have the correct Configuration selected prior to starting the drawing. To modify the text after the drawing already exists, you need to right-click on the drawing and select Modify Text. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
