Date/Time: Tue, 22 Apr 2025 18:28:08 +0000
SOLVED: Numbers Bars Min/Max Delta plot wrong if delta numbers disabled.
View Count: 646
[2023-03-16 22:47:38] |
j4ytr4der_ - Posts: 946 |
Today on my footprint I realized my min & max deltas were wrong. On closer inspection, it turns out that this is because I had turned off the numbers in the footprint, opting for just a clean delta and volume profile showing. If I turn the delta values back on (Column 1) then the min & max delta immediately return to their correct locations. Two images to show the issue (min & max are highlighted in yellow). Delta enabled (bar and pullback): https://snipboard.io/kSEZbd.jpg Delta disabled (bar and pullback): https://snipboard.io/slLQKR.jpg Is this by design? Shouldn't we be able to correctly identify min & max delta even without numbers in the footprint? Date Time Of Last Edit: 2023-03-16 23:01:26
[2023-03-16 23:08:43] |
Solved this. Found the input that was not set properly: https://snipboard.io/B6f53Y.jpg |
