Date/Time: Tue, 22 Apr 2025 18:28:08 +0000
MJY Dollar Per tick
View Count: 302
[2023-03-16 22:47:16]
aroymukherjee - Posts: 22
When backtesting on the MJY the currency value per tick is listed on Denali as 6.25. This does not match the specs you see elsewhere such as CME where it is 1.25.
Furthermore the trade window gives me a totally different value (see screenshot) - currency divided by ticks = 0.625
imageMJYDollarPerTick.jpg / V - Attached On 2023-03-16 22:46:01 UTC - Size: 184.26 KB - 92 views
[2023-03-17 14:09:43]
John - SC Support - Posts: 39418
The default Currency Value per Tick that you are showing in the Chart Settings is for the 6J symbol. Since you are using a Trade and Current Quote Symbol, you need to adjust the Currency Value per Tick to match what is needed for the Trade and Current Quote Symbol. Refer to the following:
Chart Settings: Updating Currency Value per Tick for Trade Symbol
We are not able to reproduce what you are seeing on the Trade Window. Can you please get us that chart so we can take a look and see if we can reproduce it with your chart. Follow these instructions to get us the chart:
