Date/Time: Tue, 22 Apr 2025 18:30:44 +0000
Options Expiry Charts ES YM NQ
View Count: 331
[2023-03-16 17:15:47] |
User360283 - Posts: 514 |
Is there a way to hare "continues" charts for my options trading so that I do not loose all my drawings at expiration? Help please Thanks
[2023-03-16 17:45:25] |
John - SC Support - Posts: 39418 |
First of all, refer to the following regarding setting up a Continuous Futures Contract Chart: Continuous Futures Contract Charts Second, this will not directly solve the issue of the drawings - as you need to "roll over" the drawings to the next contract when it is rollover time. For next time, when you rollover a chart and you have the window to make the selection for the next contract, there is an option on there that states Also Rollover Chart Drawing Symbols, which you will want to enable. Once you are after the fact, you can do one of two things: 1) Go to the Tools >> Manage Chart Drawings Window and update the symbols for each drawing. Refer to the following: Chart Drawing Tools: Manage Chart Drawings 2) Go to Chart >> Chart Settings >> Chart Drawings and set the option for Show Chart Drawings for Different Symbol to Yes. Refer to the following: Chart Settings: Show Chart Drawings For Different Symbols (Chart >> Chart Settings >> Chart Drawings menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
