Date/Time: Tue, 22 Apr 2025 18:33:49 +0000
Using ascil to obtain the subgraph color from of another charts study subgraph.
View Count: 749
[2023-03-16 17:01:25]
User92573 - Posts: 559
Dear Support
Although I'm able to obtain the Data from another another Charts Subgraph (Study Subgraph) to populate the current Chart, I cannot seem to Get the Color from that other charts study subgraph.
Obviously SC own Study/Price overlay does recover not just colour but all settings from another charts study/subgraph. Please can you point me in the right direction for a solution as I've pretty much searched as far as I can but obviously missed something.
Many thanks.
[2023-03-16 17:36:11]
John - SC Support - Posts: 39418
Refer to the following:
ACSIL Interface Members - Functions: sc.GetStudySubgraphColors()
[2023-03-17 10:54:03]
Hi John
Once again, thank you so much just what I needed to point me in the right direction however if you do revisit this post can I ask whether there are any studies I can reference that would provide an actual example of this applied, as I can't quite see how I obtain the COLORREF or RGB() from DrawStyle?
I realise SC doesn't provide programming help which is understandable but any additional direction would be gratefully received!
Many thanks
[2023-03-17 12:37:20]
User431178 - Posts: 654
It seems you might be reading the wrong information.
Follow the link and make sure to read the section titled sc.GetStudySubgraphColors() it is quite clear and does not reference the drawstyle anywhere.
int32_t GetStudySubgraphColors(int32_t ChartNumber, int32_t StudyID, int32_t StudySubgraphNumber, uint32_t& r_PrimaryColor, uint32_t& r_SecondaryColor, uint32_t& r_SecondaryColorUsed);
uint32_t PrimaryColor = 0;
uint32_t SecondaryColor = 0;
uint32_t SecondaryColorUsed = 0;
sc.GetStudySubgraphColors(1, 1, 0, PrimaryColor, SecondaryColor, SecondaryColorUsed);
[2023-03-17 14:31:10]
Sorry, yes I read on too far.
So, if I then create 3 vars:
COLORREF P_COL
COLORREF S_COL;
int S_COL_USED;
Can I then obtain/utilise those values using:
SCInputRef MySubgraph_For_Study = sc.Input[0]; // my subgraph
P_COL = r_PrimaryColor;
S_COL = r_SecondaryColor;
S_COL_USED = r_SecondaryColorUsed; // int value 0/1
MySubgraph_For_Study.PrimaryColor = P_COL;
MySubgraph_For_Study.SecondaryColor = S_COL;
MySubgraph_For_Study.SecondaryColorUsed = S_COL_USED;
Many thanks
[2023-03-17 14:50:18]
SCSubgraphRef MySubgraph_For_Study = sc.Subgraph[0];
if (sc.GetStudySubgraphColors(A, B, C, PrimaryColor, SecondaryColor, SecondaryColorUsed))
MySubgraph_For_Study.PrimaryColor = PrimaryColor;
MySubgraph_For_Study.SecondaryColor = SecondaryColor;
MySubgraph_For_Study.SecondaryColorUsed = SecondaryColorUsed;
Subtitute A, B & C in the call to GetStudySubgraphColors for the chart, study and subgraph of your choosing.
Date Time Of Last Edit: 2023-03-17 14:51:23
[2023-03-17 14:59:07]
That's really helpful, I was just programming it in the background the same way except I hadn't assigned values, only declared them.
That helped a great deal, many thanks!
[2023-03-17 15:01:12]
I did check using:
msg.Format("")
sc.AddMessageToLog(msg,1);
... and all worked as expected.
[2023-03-17 15:26:47]
Out of interest do you know if
sc.GetStudySubgraphLineStyle()
sc.GetStudySubgraphLineWidth()
... are now available?
Many thanks.
[2023-03-17 15:38:04]
I haven't used those yet myself, but they are in the header file from v2473+.
[2023-03-17 17:57:19]
Thank you. I'm using version 2455 and they are not there so I'll update and search again.
[2023-03-17 19:00:16]
Hmmm ... as you say its there in header but I can't compile it so it may be a work in progress.
I notice the documentation is incomplete for both items.
I'll put up a Support Board request and hopefully John or someone in programming will reply.
Date Time Of Last Edit: 2023-03-17 19:02:46
[2023-03-17 21:14:45]
The code is in place for these two items:
So you should be able to use them. What error are you getting when you compile?
