Date/Time: Tue, 22 Apr 2025 18:28:09 +0000
Pivot Points Accuracy
View Count: 492
[2023-03-16 15:08:15]
JulesC - Posts: 6
I've successfully fixed an issue with daily pivot points being inaccurate thanks to your website, by making my 15min intraday chart pivot points (daily) study reference my historical daily chart.
However, I have a 240min (4hr) intraday chart with weekly pivot points (variable period), and I'd like to make it reference my historical weekly chart. As you know, there is no "Reference Weekly Chart for Data" option in the pivot points (variable period) study.
How should I proceed?
Thank you so much in advance
Best regards
[2023-03-16 16:36:07]
John - SC Support - Posts: 39418
Can you use the Pivot Points - Variable Period set to weekly on a weekly chart and then use the Study/Price Overlay to put the Pivot lines on the 4hour chart?
Refer to the following:
https://www.sierrachart.com/index.php?page=doc/PivotPoints.html#s223
Study/Price Overlay Study
[2023-03-16 17:02:29]
JulesC - Posts: 6
Worked perfectly, thank you!
