Date/Time: Tue, 22 Apr 2025 18:24:55 +0000
Get data of main price graph, even if an indicator is set -as main price graph-
View Count: 412
[2023-03-16 14:28:42]
BenjFlame - Posts: 337
in a chart I have an indicator set as "main price graph".
In the same chart, I still want some other indicator based on the real main price data. Not indicator set as "main price graph".
How is it possible to do this? I can use ACSIL if this is the only way but please briefly tell me how.
Date Time Of Last Edit: 2023-03-16 14:32:43
[2023-03-16 15:47:23]
John - SC Support - Posts: 39418
Do not set the option for Display as Main Price Graph for the indicator you want to be in the top region (region 1). Rather, just set the region for that indicator to Region 1.
If you do not want the Main Price Graph to be in that same region, then set the option for Chart >> Chart Settings >> Regions >> Chart Region to something other than 1. Refer to the following:
Chart Settings: Chart Region (List) (Chart >> Chart Settings >> Regions >> Chart Region menu)
If you do not want to view the Main Price Graph, you will still need to change it to another region, but you can set the Chart >> Graph Draw Type to Blank. You can then shrink that region down to the smallest it will go. If you have other indicators, you probably want to put this at the bottom.
