Date/Time: Tue, 22 Apr 2025 18:08:45 +0000
Proposal
View Count: 350
[2023-03-16 11:10:30] |
User922648 - Posts: 9 |
Good morning, it would be interesting to be able to parameterize the values of the "Input Values" of the Studies with external values taken for example from a table or even better from a Spreadsheet. Example: @Sheet(A3,8). Thus the filters could be adapted to the market situation by hooking them up for example to the VIX or VXN. Thanks for the attention. |
[2023-03-16 14:17:44] |
Sierra_Chart Engineering - Posts: 19305 |
You can accomplish this using ACSIL.: Advanced Custom Study Interface and Language (ACSIL) You have the ability using ACSIL to set study Inputs. And you can interact with Spreadsheets: ACSIL Programming Concepts: Direct Programmatic Interaction with Spreadsheet Sheets Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-03-16 17:26:13] |
Thanks for the reply. I thought it could be done but you have to rewrite many used studies and often duplicate them to use them on different charts. A long job. Anyway thanks. |
