Date/Time: Tue, 22 Apr 2025 18:22:20 +0000
Link between charts
View Count: 330
[2023-03-16 10:34:39] |
User266447 - Posts: 270 |
In my instance I have several charts. When I change a symbol in one chart, a few other also make the change. How can I disconnect them? - so when I change one chart i.e. from DAX to EUR other chart will not change it?
[2023-03-16 10:57:16] |
In the message above I am reffering to a chart symbol. When I change a symbol in one chart a few others also change their symbol. How can I stop this - disconnect them?
[2023-03-16 15:12:23] |
John - SC Support - Posts: 39418 |
The most likely situation is that they are setup to have the same Link Number and are linked for the Symbol. You will need to unlink them. Refer to the following: Chart Settings: Linking For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
