Date/Time: Sun, 24 Nov 2024 07:43:58 +0000
VbP - "Always Display Last Profile Within View" for previous days
View Count: 437
[2023-03-16 03:34:45] |
User200641 - Posts: 2 |
Hello, I like to keep a daily volume profile right aligned on my chart and have the "Always Display Last Profile Within View" option enabled. When I review the previous day's trades/price action, I scroll back but the volume profile is attached to the last candle of the day and not visible. It would be nice if the profile for the most recent visible time frame was attached to the right price axis even if it's not the current day. I can use the replay functionality as a workaround for now but would appreciate if this feature was available. Thanks! |
[2023-03-16 15:06:05] |
A couple of workaround options for you: - Add a Volume by Price profile to the Right side that covers the time period of the previous day. This way it will always be visible as you scroll through the day. - Change the Number of Periods Back to Reference to 1 on the VbP that you have displayed with the option to Always Display Last Profile Within View. This way, the last profile is referencing the previous day. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-06-16 06:55:12] |
User967293 - Posts: 1 |
Exactly the same issue, I have never found a workaround despite the numerous options of VBP. Meaning : unable to display correctly the right aligned profile when reviewing past sessions. In fact, Always Display Last Profile Within View only works when the volume profile is left aligned. Which is a very good improvement, but if it worked for right aligned profiles as well (because lock fill space frees some space to the right), it would be terrific Date Time Of Last Edit: 2024-06-16 07:02:37
