Date/Time: Tue, 22 Apr 2025 18:30:45 +0000
BAAVG chart isn't showing mid price when compared to DOM
View Count: 322
[2023-03-15 23:59:52] |
User799255 - Posts: 24 |
Can I get some help checking this please? According to screenshot the chart price should be showing 1943.5 as the mid price. Thank you |
Attachment Deleted. |
[2023-03-17 14:26:07] |
Sierra_Chart Engineering - Posts: 19305 |
Refer to: Data Recording Modes: -BAAVG It is explained there. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
