Date/Time: Tue, 22 Apr 2025 14:20:38 +0000
I found a bug of Volume By Price Study
View Count: 537
[2023-03-15 14:42:16] |
NanWangIDa - Posts: 10 |
If I select "POC, VAH, VAL, VWAP Lines Only" at Draw Mode and set POC, VAH, VAL, VWAP "Extend To Both Window Edges", then POC, VAH, VAL, VWAP will not extend. However if I select "Volume Profile & POC, VAH, VAL, VWAP" at Draw Mode and set POC, VAH, VAL, VWAP "Extend To Both Window Edges",it works. But I just want to see POC, VAH, VAL, VWAP Lines Only and extend them, could you fix it? Thanks |
[2023-03-15 16:23:46] |
Use the Subgraph Draw Style options instead. Set the Draw Style to Line at Last Bar Left to Right. Refer to the following: Chart Studies: Line at Last Bar Left to Right (ACSIL: DRAWSTYLE_LINE_AT_LAST_BAR_LEFT_TO_RIGHT) Just be aware that if you do this with the VWAP, you will only get the last value for the VWAP. Also, It is not unusual for lines to not be drawn when you are not within the period for that particular VbP. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
