Date/Time: Mon, 16 Sep 2024 19:06:50 +0000
slow chart loading times
View Count: 1686
[2014-06-16 20:27:36] |
User77503 - Posts: 48 |
every time i start up my workspace in the morning or if i switch a chart from RTH to 24hr time frame it takes well over a minute for it to load because it has to calculate every single futures month it seems ("loading ESM3, ESU4..."). am i doing something wrong by not having all that already permanently downloaded or???
[2014-06-16 21:28:29] |
Historical data that already exists within a chart data file, is not downloaded again. We recommend referring to help topic 30 for this kind of issue: http://www.sierrachart.com/index.php?l=doc/helpdetails30.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-06-17 16:21:30] |
what specifically about it? there are 29 bullet points. do you believe your charts should load in less time than a minute or is my wait normal?
[2014-06-17 16:29:08] |
Should be much less than a minute. However, there are so many different variables involved it is hard to say. Your own system can have a major effect upon chart loading times. The main thing that will help is reducing the Days to Load in Chart >> Chart Settings. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-06-17 16:29:44
