Date/Time: Tue, 22 Apr 2025 14:08:54 +0000
DOM Sell & Buy Column
View Count: 416
[2023-03-15 13:09:41]
Sir Chart - Posts: 1
Could anyone help me sort this problem please. On the BUY and SELL column of DOM Chart there are NO order numbers, it shows only 1 on SELL and 1 on BUY. This doesn't work for Forex. It shows all the SELLS and BUYS when I use same setting for BTC, IDEXES
If anyone know how to fix this, please help!
Thank you in advance!
[2023-03-15 15:55:34]
John - SC Support - Posts: 39395
We need you to post on the Support Board with your active Sierra Chart account. To do that select "Help >> Support Board " from within Sierra Chart.
If you did not get an answer to your prior question, post here again after doing the above confirming that you have logged in with your current account to let us know.
