Date/Time: Thu, 19 Sep 2024 01:07:33 +0000
Initial Balance on volume graph
View Count: 1374
[2014-06-16 20:26:11] |
User90003 - Posts: 21 |
Hi, I use 30 min timeframe and for example 1000 volume graph on the same symbol (eg AUD 6A). I use studies "Initial Balance Levels". At 30 min. graph studies OK, but on the volume graph is diferent IB. How can I make a graph volume 1000 with the same volume IB as a 30 minute chart? Thank you.
[2014-06-17 10:36:20] |
You have to overlay it from the 30 minute chart. Refer to help topic 28 here: http://www.sierrachart.com/index.php?l=doc/helpdetails28.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
