Date/Time: Thu, 28 Nov 2024 22:28:33 +0000
adding custom horizontal ray config to shortcut menu
View Count: 425
[2023-03-15 09:51:46]
fish4trout - Posts: 99
I have a few custom horizontal ray configurations set-up with specific text labels and line colors. I want to add these custom horizontal ray configs to my shortcut menu since I use them daily. I currently have a horizontal ray on my shortcut, but have to select the specific config every time I draw them.
[2023-03-15 15:35:56]
John - SC Support - Posts: 36350
There is not a way to do it for the right-mouse menu, but you can do it for a Control Bar button. Refer to the information here:
Chart Drawing Tools: Creating Control Bar Buttons which Select Drawing Tool and Drawing Tool Configuration in One Step
[2023-03-22 23:05:44]
This worked thanks!
