Date/Time: Fri, 29 Nov 2024 00:49:04 +0000
Binance Data Feed Lagging
View Count: 592
[2023-03-15 06:07:57]
User486817 - Posts: 83
hello,
currently the binance data feed is showing significant lag. for BTCUSDTPERP, the latest price reading i have is 03:40:06 UTC at $24762. i have six pairs up from binance and they are all lagging but in different degrees. some update, while others are frozen. i also have up CLJ23, GCJ23 and SIK23 simultaneously and those are working normally.
thank you for your help in advance.
kindest regards,
[2023-03-15 10:13:52]
hello,
this issue seems to be fixed now. i swear, you guys are the best.
kindest regards,
[2023-03-15 15:32:34]
HukaChoo - Posts: 12
Its just me or nance data not usable for like 3 days? gaps, freezes, no response
[2023-03-16 14:19:51]
Sierra_Chart Engineering - Posts: 17213
There are going to be numerous problems with Binance. The source data feed from Binance is not good. It is what it is. We do not know how to make this any better and we are not putting any effort into that.
If you have problems, there are going to be problems. There is no effort we can do to help this and we do not know what more we can do.
We recommend using Bitmex symbols.
