Date/Time: Tue, 22 Apr 2025 14:38:20 +0000
Dom and chart different price.
View Count: 355
[2023-03-15 05:48:09] |
kremat0r - Posts: 47 |
Hello, Im facing some problem. Few times Dom shows different price than a chart. I reset a sierra, make update etc. nothing helps. For now 6:46 last price for FDAX was 15388, On dom I can see 15361 on chart 15388. I cannot fix it https://www.sierrachart.com/image.php?Image=1678859248192.png Date Time Of Last Edit: 2023-03-15 05:48:37
[2023-03-15 14:45:25] |
Make sure the Session Times are set the same for the Chart and the Trading DOM. Refer to the following: Chart Session Times For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
