Date/Time: Tue, 22 Apr 2025 18:28:07 +0000
Volume distribution in a period
View Count: 494
[2023-03-15 02:10:41]
User250096 - Posts: 7
Hi there,
in sierra, is there a study can show a percentile(for example, 70% from the lowest price) of volume distribution? It is a little like Volume Distribution Paint Bar Study, but it calculates once in a certain period like VbP, not once per bar.
Date Time Of Last Edit: 2023-03-15 02:39:52
[2023-03-15 14:27:08]
John - SC Support - Posts: 39418
Not sure what you need.
Look over what the Volume by Price study offers:
Volume By Price Study: Volume Graph Period Type
[2023-03-16 02:28:02]
Sort all transactions in a period of time by price (from low to high or from high to low), and display the price of the specified percentage position
[2023-03-16 15:02:02]
There is not a direct way to do this. But one way would be to create a chart that is just the period you are interested in. Then add the Spreadsheet Study to that chart and set the Input for Output Volume at Price Data, which will give you the Volume At Price Data within the Spreadsheet starting at Column BA. You can then use the Spreadsheet Study to do the math you want on that data to get the level you are looking for. Refer to the following:
Spreadsheet Study Inputs: Output Volume at Price Data
