Date/Time: Thu, 28 Nov 2024 22:33:18 +0000
Highlight candle based on alert
View Count: 401
[2023-03-15 00:23:25]
fish4trout - Posts: 99
I'm wanting to highlight a specific candle/numbers bar when "Finish AskVol Bidvol Diff" = 0 in the numbers bars calculated study. Any help would be appreciated!
imageimage 1.png / V - Attached On 2023-03-15 00:22:43 UTC - Size: 30.54 KB - 100 views
[2023-03-15 14:26:01]
John - SC Support - Posts: 36350
You can not highlight a Numbers Bar. You could place some kind of marker at the top or bottom, if that is what you want.
But, you can color the candle for a standard chart.
In either case, you will use the Color Bar Based on Alert Condition. In the Alert Condition you will enter the following:
=ID1.SG34 = 0
Refer to the following for this study, and note the section for "Drawing Arrows/Text or Other Styles at the High or Low of Bars":
[2023-03-22 23:06:01]
Great thanks!
