Date/Time: Thu, 19 Sep 2024 00:18:16 +0000
Data breaks
View Count: 1010
[2014-06-16 20:16:04] |
User90003 - Posts: 21 |
Good day I have a problem with the data. I have data from OEC. If I use the data for index futures (ES, YM, NQ), I have no problem here. When I want to use the data for 6E EUR and 6A AUD, so my data breaks in reading and I have to make a "download and Delete Data". This problem is for all timeframes. Countdown ends at "00" and retrieving the data stops. Can you help me please ? |
[2014-06-16 21:27:48] |
You probably are going over the 5 symbol limit with OEC. Refer to this section here: http://www.sierrachart.com/index.php?l=doc/openecry.php#Symbols Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
