Date/Time: Tue, 22 Apr 2025 18:24:56 +0000
Custom Study Manager Group
View Count: 680
[2023-03-14 18:22:53] |
SierraTraders - Posts: 69 |
When in Custom Study Manager Group Select a Custom Study File Name to manage from the list below: as one study has been added is it possible to have more than one in list if so how to add study |
[2023-03-14 20:38:25] |
John - SC Support - Posts: 39418 |
You can have as many of these items as you want. Essentially each one is a grouping of files that you want to make available to some group of people. So you have 1 (grouping) right now, to which you have added 2 files. You can add more files to this one group, or you can have us add another group (or more) to which you will put specific files in those. Each grouping has a different set of people that can get those files.
[2023-03-16 12:56:30] |
is there anyway to edit or delete a post in the studies store....?
[2023-03-16 15:19:47] |
Go to the Manage Details page and deselect the option for Include in Store. You get to the Manage Details page by selecting the link when you are within the Custom Studies Control Panel for the particular study, it is under the Study Store section. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-03-21 11:34:28] |
ManuelEmanuel - Posts: 7 |
Hello John, I have a question. I need help finding the Manage Details page and deselecting the option for Include in Store. Any assistance, please? Also, I know it's definitely possible to have more than one study in the Custom Study Manager Group list. To add another study, you just need to follow a few simple steps. First, make sure you're in the Custom Study Manager Group. Then, click on the "Add Custom Study" button to create a new study. Once you've entered all the relevant information for your new study, it should appear in the list along with any other studies you've added. I did a beauty of mathematics in nature essay inspired from https://samploon.com/free-essays/mathematics-in-nature/ and firstly, it was complicated how to edit my study. However, I found that to edit or delete a study, just click on the appropriate button next to the study in the list, and my research was done successfully. If you want to re-order the studies, you can simply drag and drop them into the order you prefer. Hope that helps! Let me know if you have any other questions. Date Time Of Last Edit: 2023-03-31 08:38:28
[2023-03-21 14:27:30] |
Sierra_Chart Engineering - Posts: 19305 |
What is the name of the custom studies you want removed from the store?
